2010 crawler injector pump
Richard G.
08-25-2005 07:16:42
About to take off a 2010 crawler injector pump. Is there anything I should be particularly careful about while doing this? Maybe check the timing first or anything else? Going to take the pump to be rebuilt.
Thanks, Richard
msb
08-25-2005 17:19:15
 Re: 2010 crawler injector pump in reply to Richard G., 08-25-2005 07:16:42
Just to make reassembly easy,line the timing marks up in the timing window before you remove it.The 2010 pump did not have an offset drive shaft tang like the bigger tractors did,so it is possible to get it 180 degrees off and still be able to bolt it down.
