Acceptable taper on Cylinder - JD 620??
JDVan
08-24-2005 21:54:36
What is accpetable taper on a cylinderwall for a Gas 1958 JD 620? If the taper is more than some accpetable number what problems appear?
Mike M
08-25-2005 06:59:46
 Re: Acceptable taper on Cylinder - JD 620?? in reply to JDVan, 08-24-2005 21:54:36
Had to cut short,boss was watching. LOL Problems from excess taper I would say would be some loss of compression causing more blow by and a slight loss of power than if bored out.And a shorter life if worked hard. But if you just put in the new rings you are still going to see a decrease in blow by and an increase in power over what you have now. If it don't suit you or last long it can always be bored out later.
Mike M
08-25-2005 06:37:27
Those tractors have skinny rings prone to breakage when the bore and ring grooves wear. Most of the wear is going to be on the upper top of the bore back to only 2" ?
I guess the book allows maybe up to .007 or .008 ? I stuck a model 60 back together for a fellow that was around .015 with very good results.And a model MT (cracked block wasn't worth boring)with around .020 as bad as it was it helped it out tremendously.
BushogPapa
08-25-2005 05:28:52
Unless it has a Massive amount to cut out at the top ridge, I think you are ok for the 1st rebuild.. Just remember, you must hone ALL previous ring wear marks out of the cylinder, and you need to judge the condition of the pistons too.... Worn ring-lands, worn wristpins or worn piston skirts render them not worth re-using sometimes.. Proper honing and initial break-in are critical.. You only have about 20 minutes of run-time to put the engine under a load, to seat the rings...or the cylinders will be too glazed to seat them.. Last 630 I overhauled, I had to hone each cylinder about 45 minutes each to get them "right", and it sure sounds like it will work with the best of them.. One thing..have you checked the mains..?? At least pull the flywheel and the left main to see what condition the gasket is in that seals the main bearing oil passage to the crankcase... Mine had only a flow the size of a pencil lead, and the Rt one was closed off almost totally... If they have never been changed, I would at least pull them and change the oil-delivery-gaskets for the Main bearings... That gasket "cold-flows", closing the oil passage...sorry to say, there is no way of knowing without pulling the Main caps...not expensive, but the clutch-side is more work than the flywheel side...
Ron.
