'49 A trouble
roy in iowa
08-24-2005 16:30:16
Had a free afternoon and decided to take the old girl for a spin. Batteries are dead. Hooked up to my '63 Chevy and pull-started her. Now she runs okay at 3/4 throttle, but any less and she dies. I ran her for an hour, then put her away. A week later, no juice in the batteries. I've had her for 1 1/2 years and would run her around the neighborhood once or twice a month. She sat all summer, and now she's ailing. I'm kind of new to the mechanic end of 2-cylinders. Appreciate the help!
Lee B
08-24-2005 22:20:12
 Re: '49 A trouble in reply to roy in iowa, 08-24-2005 16:30:16
Sounds like a problem with your charging system or a dying battery? At 3/4 throttle the generator is making enough juice to power the coil but at any less speed, it doesn't? Of course if you had stated that you had a magneto then my angle doesn't work at all.
Disconnect the battery and charge it up, then check it's voltage the next day to see if the battery is failing or not. My bet is that your generator cutout relay has welded itself ON due to large charging currents a dead battery demands and instead of disconnecting the battery from the regulator and generator's feild coils when the engine stops, it then draws all the current out of the battery leading to a vicious circle. You might be able to break the circle by using an already charged battery to start the tractor and when done with it slap the regulator to help pop the points free. Otherwise it's file the cutout relay points and then get a new regulator in that order? All depends of course on what you got for an ignition source (mag VS point-coil), generator VS alternator for a charging system, and the age/condition of your battery. A little more info next time, please.
roy in iowa
08-27-2005 16:34:51
 Re: '49 A trouble in reply to Lee B, 08-24-2005 22:20:12
Thanks for the tips! She does have a magneto. Seedcorn picking starts Monday, so she may have to wait for a couple of months. Thanks again!
johndeereman
08-24-2005 17:56:14
id check the points first they tend to corrode if it sets for a while next check youre gas does it have water in it or is it stale 89 octane is only good for 30 days hope this helps
