70 LP, check your fuel lines, don't get burnt
Rev JJ
08-24-2005 16:18:12
This just happened last September. I was severely burned by fire from a 70lp with improperly made fuel lines that appeared to be OK.
The 70lp in question was one I had only recently acquired. I am really, really careful about LP equipment, as I was brought up on it. When I got the tractor it was represented to me that the fuel lines, ect. were all recently changed, and appeared to be as represented. The guy I got the tractor off of (now deceased) was a very prominant dealer and collector, and knew him to be a man of his word.
I regularly soap lp gas lines to make sure nothing leaks, and had done so just a week before.
Long story short the main fuel line turned out to just be regular, non re-enforced gas line that had pressure ends "crimped"on it. I was pulling a BWA disc and the fuel line ruptured as I was turning at the end of the field and ignited from the distributer. I pulled the clutch back and bailed over the side as the tractor deck was engulfed in flame.
I am fortunate to be alive, and thankful that all I had was 3rd degree burns on my forearms and severly blistered face (It takes a long time to get the smell of barbecued YOU out of your nostrils).
I could go on about how hard it is to get a 911 operator to understand that you are injured in a field, and not at the address of the cell tower you are calling from, and I really can't understand all the fuss over Opium, as morphene did little to ease the pain of burning.
But I have healed up nicely, with the Lords help and tender care of my RN wife.
Check those fuel lines, though.
Mike M
08-26-2005 10:48:24
 Re: 70 LP, check your fuel lines, don't get burnt in reply to Rev JJ, 08-24-2005 16:18:12
Did your tractor burn up ? Did your valves have the thing in them that shuts them off with a big leak like that ? I can't remember if the originals do ? I think some I used for replacement on a 730 did.
woodbutcher
08-24-2005 18:52:53
I'm glad you're okay. I've had some close calls with LP, but I still have a 3010 that uses it. You can't be too careful.
Butch
