3150 FWD knuckle housing/tie rod slop
DavidG
08-24-2005 12:32:02
Hey folks!
Please tell me there is an way to repair a sloppy tie rod hole on the fwd knuckle housing without replacing the housing ($$$).
R. John Johnson
08-25-2005 13:22:15
 Re: 3150 FWD knuckle housing/tie rod slop in reply to DavidG, 08-24-2005 12:32:02
Years ago I read in Farmshow about a machinist who had a fix for that problem. He had a jig that bolted on to existing holes to allow him to bore the hole out and (I think) press in a sleeve. Try looking up Farmshow on the web and check their index.
John
G/MAN
08-24-2005 15:59:44
David, I'd be willing to bet a competent machine/welding shop could fix you up there. That housing should be pretty much steel, so welding the hole shut and machining out a new one shouldn't be too difficult, but I'm not a machinist by any means. You're going to want it located pretty much right where it is, but adjustment in the tie-rods and the ability of the rod-end itself to flex should be able to make up for any minor error. I'd definitely get an opinion on it from a good machinist before plopping down the $$$ for a new one.
