4430 exhaust leak
Max Moo
08-24-2005 05:54:45
Has anyone come up with a solution for the persistant exhaust leak between the turbo and the exhaust manifold on a 404d with a turbo? I'm getting sick of breathing exhaust. I've replaced all the parts but after 1000 hrs its leaking again.
bryan s
08-24-2005 20:04:02
 Re: 4430 exhaust leak in reply to Max Moo, 08-24-2005 05:54:45
we use a gasket/seal that is standard on some IH tractors -i dont know a part # is but it fits perfect in between the sleeve and turbo and 'shims" it tight.i bet your local IH dealer would have what im talking about-we use it it for these leaks on JD's 404 and 466 all the time
G/MAN
08-24-2005 10:32:35
It's leaking at the 4-bolt flange itself? With new parts? Did you use the proper stainless hardware and anti-sieze, the right gasket and torque to specs? I've seen a lot of leaks at the coupler that CMB is speaking of, but very rarely at the flange if everything is in good shape and properly assembled. I'd make sure the leak IS at the flange, and not the coupler.
CMB
08-24-2005 06:13:31
On my 7520, I used High temp (red) silicone, was surprised at how well it worked. Eventually it started leaking again because the clearance had worn/vibrated really big, so having a lathe, I turned a slightly larger new coupling, but still used red RTV when I reassembled it. This was several years ago,& it's still holding. If yours isn't real loose, I'd clean it very well, & seal it with red RTV. Never know, you might get lucky!
