Cab glass remove and reinstall
Nylon
08-24-2005 01:39:56
I am going to pull out the glass on the cab to paint. I know that you pull the center rubber to get them out. I am wondering what kinds of tips and tricks you guys have for putting that rubber strip back into the other rubber. Soap water or other.
Thanks,
John
JDBert
08-24-2005 11:59:40
 Re: Cab glass remove and reinstall in reply to Nylon, 08-24-2005 01:39:56
Make sure to take a marker and mark each windows location and inside and outside and keep the rubber that they come out of with that window. You'll be happy you did when you reinstall them. Use soapy water or tire soap and a window install tool. Plastic spades and the other tool has a short stubb on the end with a small roller bearing (locking tool, used to lock the rubber trim flap back in)
MSM
08-24-2005 11:18:59
There is a tool to reinstall the rubber ribbon. Check with a good auto parts store or glass shop to see if they can order it for you. It is fairly inexpensive,and makes quick work of the install,and it beats the heck out of jamming a screwdriver through your hand or breaking the glass. A little soap and water or silicone spray helps too.
msb
08-24-2005 07:57:28
There is an easier and much faster way John.There is a tape that has a plastic strip which can be stuck under the rubber seal.Tuck it under the seal and stick the tape to the glass. I forget the name of it ,but any body shop should be able to tell you about it.It is very easy to use and makes for a professional looking job.The tape(plastic strip) comes in different widths.I think I bought the 1/2" strip for the last tractor I painted.NAPA carries it.
Nylon
08-24-2005 10:55:14
 Re: Cab glass remove and reinstall in reply to msb, 08-24-2005 07:57:28
MSB,
I would tape them off but there is enough bleed through rust that I want to sand them down. The only way to really sand them down good it to get the moulding off so I can sand flush and get above the windows.
The tip on the plastic strip is handy though as I will use it on the wifes car when I do it.
Thanks,
John
