Ammeter Reading
JDAW1948
08-23-2005 18:33:06
I have converted from a Generator to a Alternator on my 1948 AW and I"m wondering were the Ammeter should read. When I start the tractor now the needle goes all the way over to plus 20 and almost pegs. After a minute or so it goes back to + 15 or 10. Is this the normal reading or will I be burning my points. I have both the 10 ohm 10 watt resistor and the 50 volt diode in series between the #1 terminal on the alternator and the ignition switch. Any information will be appreciated.
Bob M
08-24-2005 10:33:55
 Re: Ammeter Reading in reply to JDAW1948, 08-23-2005 18:33:06
I agree with John T - what you are seeing is perfectly normal with an alternator conversion and using the original ammeter
FWIW the alternator (Delco 10SI) on my Super M causes it's 20 amp ammeter to peg HARD for 20 - 30 seconds or so after the engine starts. (Testing with with a clamp-on ammeter indicates 50+ amps flowing...)
Also as John T states there�s no danger of burning your points. If you were to take a voltage reading when the ammeter is pegged you�ll find system voltage is actually a few tenths of a volt LOWER when it's charging hard. The high current is caused by the alternator trying to bring system voltage back up to normal.
John T
08-23-2005 19:01:27
AW, if its a GM 10 SI Alternator like mine, they are capable of even higher amperage and what you say is similar to how mine acts. If its cold n it takes a lot of cranking, mine charges at around 20 amps fer a while then settles back to 10 then maybe 5 later.
That 10 ohm resistoir is there to protect the alternators small diode trio and it shouldnt be causing any problems, Ive seen then run fine for years with no resistance and even up to over 10 ohms with nooooo oooo problem. The other series diode is simply there to prevent the coil from getting back fed so when you turn the ignition off she will die.
I dont see any concern for burning any points. Even if the alternator elevated the battery voltage from 12.6 to 14 temporarily I see no problem. Its only if the Alternators voltage regulator circuit failed and it charged constantly at well over 20 amps or more the battery could become overcharged and outgas and/or boil acid over.
John T
