Changing filler neck on JD D
tractorboy
08-23-2005 17:23:21
I have late model D whose filler neck has seen its better days. I bought a replacement from K&K but am now wondering how I can get the old one off and put the new one in. Is the neck brazed, welded, or soldered in the top of the radiator.
I would like to do this job myself and on the tractor since the thought of taking off the radiator on this tractor is not something I am looking forward to.
Has anyone done this before?
tractorboy
08-23-2005 17:46:18
 Re: Changing filler neck on JD D in reply to tractorboy, 08-23-2005 17:23:21
Never mind, I found my answer with a search on the board. Cut the neck with my dremel, chisel it out, then press fit the new neck with a board.
mike brown
08-24-2005 04:32:28
 Re: Changing filler neck on JD D in reply to tractorboy, 08-23-2005 17:46:18
I was guessing it would need soldering
tractorboy
09-06-2005 05:25:10
 Re: Changing filler neck on JD D in reply to mike brown, 08-24-2005 04:32:28
Since the system is low pressure, I was thinking of coating the outside of the new neck and the inside of the radiator with some red sealant.
