Deere 130 mower deck belt problem
Dpope60
08-23-2005 15:58:21
I recently purchased a JD 130 - 1987 with a 30" mower deck. It runs great, needs brakes though. It didn't come with a belt for the deck so I went to the JD dealer and got a new one. According the specs I have the correct belt. Problem is the blet is about 2" to long.
Can anyone help me?
Joe M(GA)
08-23-2005 17:28:24
 Re: Deere 130 mower deck belt problem in reply to Dpope60, 08-23-2005 15:58:21
be sure they sold you a M90958 belt, that or you"re on the wrong side of one of the pulleys
dpope60
08-23-2005 17:41:24
 Re: Deere 130 mower deck belt problem in reply to Joe M(GA), 08-23-2005 17:28:24
Thank you for replying. I really need help on this one.
Yeah, it"s the right belt. I don"t have a diagram of how the belt goes on but we have tried it every way we could think of. I am wondering if I am missing a part. There are 2 pulleys on the deck. One is small and flat on the inside, behind that is the main deck pulley that turns the blade. Other then that there is the PTO pulley at the other end.
Thank you,
Scottie
Joe Padavano
08-24-2005 16:52:38
 Re: Deere 130 mower deck belt problem in reply to dpope60, 08-23-2005 17:41:24
I went through this same problem with the 130 that I recently bought. The previous owner had screwed up the spring-loaded belt tensioner pulley on the mower deck and I had a lot of trouble getting the belt on. It either seemed to be too long or too short.
First, be sure that the "L" shaped mower lift arm is installed correctly. The arm should be vertical as it comes off the mower deck; the end with the keyhole slot should be on the top and approximately horizontal. The tensioner pulley must be able to move back until it almost touches the vertical leg of this lift arm. That should give you enough movement in the tensioner pulley to use the belt you have.
Joe Padavano
