JD 530 Roll O Matic
JonND
08-23-2005 10:55:33
I need to replace the knuckles on my roll-o-matic. The part numbers are B2711R and B2712R. Are these parts common across several models or were these parts only used on the 520 and 530?
Any leads I can follow up on would be appreciated.
Thanks
Jon in North Dakota
Mike M
08-23-2005 12:14:15
 Re: JD 530 Roll O Matic in reply to JonND, 08-23-2005 10:55:33
Or you could swap the whole thing out for one off a 60 or similar tractor as these were the optional heavy duty for the 50,520,530
TylerARK
08-23-2005 11:25:56
Jon, The part numbers to match those casting numbers are- AB3771R and AB3772R.
JD EPC shows them fitting B from serial # 60000 and up , 50 and 520 & 530.
Tyler
