630 clutch problems
as
08-23-2005 09:01:27
The pulley on my 630 will spin even when the clutch is disengaged. I did some adjusting of the clutch some time ago. Did I get it too tight or what? Thanks for any help.
buckeye al
08-23-2005 14:20:55
 Re: 630 clutch problems in reply to as, 08-23-2005 09:01:27
Good info from other posts but also please check the condition of the three springs that push the outer plate away from the pulley. If weak or broken, they'll tend to do this & also be reluctant to stop. BTDT.
Later.
Myrl
08-23-2005 11:50:43
Check for dirt or rust between the clutch plates. You may have to disassemble the clutch and clean it. Also a loose broken piece of clutch facing may be floating around causing it to run.
