3020 injector pump timing
Richard G.
08-23-2005 05:58:49
Just had the injector pump rebuilt on a 3020. How do you time the pump when installing it on the tractor.
Thanks,
Richard
twopop
08-23-2005 15:04:42
 Re: 3020 injector pump timing in reply to Richard G., 08-23-2005 05:58:49
turn the engine to 0 degrees tdc.there is a mark on the flywheel.you will know if you are on #1 cylinder when you look down into the fuel pump drive ,there is an upside down V stamped on the drive,it should be pointing at the rear of the engine,about 10.30 on the clock.take off the timing window of the pump and turn the shaft to line up the two marks in the window.install the pump.snug the nuts that hold the pump down,but not tight.recheck the marks in the window,when they are in line tighten the nuts(you line up the marks by moving the pump sideways) turn the motor over two times by hand ,bring it back to 0 degrees.make sure the lines still line up in the window.put the cover back on,hook the lines and throttle rod up, prime it and start it up.
Richard G.
08-24-2005 05:46:29
 Re: 3020 injector pump timing in reply to twopop, 08-23-2005 15:04:42
Thanks, It worked just like you said.
Richard
