H Reassembly
Trigg
08-22-2005 20:02:42
Can some one reccomend how far I should go reassembling my H before I start painting?
Glen in TX
08-23-2005 11:20:50
 Re: H Reassembly in reply to Trigg, 08-22-2005 20:02:42
I'm kinda with Mike on this. Just do what works for you. You probably noticed the underside of hood was rusty and no paint. Many will paint each piece separate and assemble and then touch up or put them together and paint as one. Most like to prime and paint the undersides of the hoods and sheet metal and some may not. I may prime and paint some small parts with a can as I go to keep from rusting again and then spray it all again later with a spray gun. Everyone does it different.
Trigg
08-23-2005 16:40:23
 Re: H Reassembly in reply to Glen in TX, 08-23-2005 11:20:50
Thanks for the info
Mike M
08-23-2005 04:42:57
To each his own. I'm sure there is no right and wrong answer. I'm betting the factory waited until the very end though. I kinda painted some stuff as I went ,used a brush alot then when it was to the point of being sealed up pretty much together I'd spray it.Do whatever you feel comfortable.
