2520 pto problem Please help!
David G
08-22-2005 16:03:14
My diesel, svnch-range 2520 pto problem:
It started out not shutting off completely. Now it runs for 1hr, then slows down but doesn't stop. Sounds like a clutch, right? My dealer says it doesn't have a pto clutch! I've changed the filter, fluid and cleaned the intake screen. Could it be the pto control valve?
Thanks for any help!
MSM
08-23-2005 10:47:35
 Re: 2520 pto problem Please help! in reply to David G, 08-22-2005 16:03:14
You either need the linkage adjusted,or the pto brake is worn out. The brake is not in the clutch area,it requires a split farther back in the transmission.
Tx Jim
08-23-2005 04:05:12
 Re: 2520 pto problem/linkage?? in reply to David G, 08-22-2005 16:03:14
David,I can't remember as it's been 20 yrs since working for dealer in shop but if 2520 is similiar to late 4020 pto control,the linkage inside under dash can get loose.It would be worth the time to pull the side cover off and check linkage before splitting. Jim
HTR
08-22-2005 18:43:33
The 2520 does have a hydraulic valve, and two small hydraulic pistons, that engage the PTO clutch. Try taking the plate off the bottom of the the clutch housing, and see if the PTO bearing is moving away from the PTO fingers, when the lever is pulled back. Pulling the lever all the way back should engage the pto brake, if it is not worn out.
G/MAN
08-23-2005 07:47:11
 Re: 2520 pto problem Please help! in reply to HTR, 08-22-2005 18:43:33
You're right about the valve. I dropped the ball on that one.
G/MAN
08-22-2005 16:51:39
If your 2520 has a PTO shaft, it most certainly has a PTO clutch. This is a John Deere dealer you'e working with? Perhaps some wires got crossed and the point was that your 2520 doesn't have a PTO clutch PACK, which would only be found on a Power Shift tractor. The PTO clutch on your tractor is integrated into one assembly with the traction clutch that drives the wheels. It uses a separate disk and and a pressure plate that is driven directly by the flywheel, so that the PTO can be engaged anytime the engine is running, making it "live" regardless of whether your foot is on the traction-clutch pedal or not. If your PTO slows down but doesn't stop after a period of time while there is a load on it, then the clutch is slipping. The PTO-clutch is mechanically-actuated, so there is no valve involved in applying it. It's possible that the seal on the tranmission input shaft is leaking oil onto the clutch disk, causing it to slip, or there could be other problems involving excessive disk wear, the linkage, etc. I'd recommend getting ahold of a manual or find someone familiar with those clutches to help you diagnose it.
David G
08-22-2005 17:23:33
 Re: 2520 pto problem Please help! in reply to G/MAN, 08-22-2005 16:51:39
Many thanks, G/MAN. Your answer explains the online parts diagram. I have no idea why the dealer couldn't have told me this. Anyway, it sounds like the tractor needs to be split.
