G oil fiter leak
Junkman
08-22-2005 15:47:36
After changing oil & filter on 46 GM, manual said not to over tighten nut, but after small amount of torque, notice most of new oil on the ground. After cranking more than thought necessary, still have a slow drip on nut. Any suggestions? Thanks
MIKE BOURBON
08-23-2005 04:13:07
 Re: G oil fiter leak in reply to Junkman, 08-22-2005 15:47:36
change crush washer under nut .
G/MAN
08-22-2005 15:53:31
Yes, as Maark said, make sure the o-ring is there. It's usually wedged up in there pretty good, but it could have fallen out into the oil bucket or something. You definitely don't want to overtighten the filter cover, but you still want it pretty darn snug. If overtightened, you can deform the top of the tin "can" that the filter slides up in, which can result in a blown gasket at the oil-pressure relief housing, and a big internal oil leak and possible loss of pressure.
Maark
08-22-2005 15:50:12
Did you replace the d-ring type packing that the cap tightens up against? In that small groove around the filter canister?
Junkman
08-22-2005 17:56:32
 Re: G oil fiter leak in reply to Maark, 08-22-2005 15:50:12
Maybe that is the problem, it looked to me like the new rubber ring that came with the filter pressed up against a flat surface, I guess the old one wasn't dug out of the groove.
