Freshly rebuilt 2010 D vs. other choices
Nathan in Texas
08-22-2005 14:47:38
Well, I have a lead on a 2010 w/ loader for a decent price ($2,500). It has had the engine completely rebuilt within the past 2 years. I researched these and know they are not a very popular tractor due to some of the engine troubles and some have reported hydraulic problems, pto problems, etc.
The question is whether a freshly rebuilt 2010 would be better than an unknown other tractor. I've been looking at some utility international tractors and most are online or at a dealer and you can't really get a good feel for the history of the tractor and it seems like a crapshoot vs. the known history on the freshly rebuilt 2010.
I've read all the old posts on 2010's on this site and the articles the guy from australia wrote when he rebuilt his. The rebuild was complete with the sleeve unit replaced, etc.
Just thought I would see if I could get any input on from you green fellas. I have a Farmall M and am very happy with it and that's why I've been pretty much looking along the IH lines for a utility tractor. It will be doing pretty light work and probably won't get more than 50 hours on the clock during an average year at my place.
Thanks for any input.
Nathan
donmyeil
08-23-2005 12:34:41
 Re: Freshly rebuilt 2010 D vs. other choices in reply to Nathan in Texas, 08-22-2005 14:47:38
Send me the $2500 and thank your lucky stars you dont own the tractor. Many parts are not available anymore and they are one of the most exzasperating tractors to work on you will ever find. Mother Deere should have recalled all of them. Now the 2020 and newer is a different story. Run fast as you can the other way!!! Don
Nathan in Texas
08-23-2005 13:04:28
 Re: Freshly rebuilt 2010 D vs. other choices in reply to donmyeil, 08-23-2005 12:34:41
Don,
How many of these have you owned or worked on? Do you have any personal experience or are you just repeating what you have heard about them? Any specific problems that you encountered?
I'm just trying to sort out rumor vs. hands on experience. I appreciate any input and am trying to get as many facts together as I can before making a decision one way or another.
Thanks, Nathan
Mike M
08-22-2005 19:14:05
You may as well go for it and take a chance. At that price you can't even buy an 8N Ford. I have heard all the bad stories of the 1010 & 2010 and a few good. Since being on line I'm begining to wonder if they aren't all that bad ?,because there still seems to be an awful lot of them running around they can't be total pieces of junk or they wouldn't of made it 40 + years ?
KEH
08-22-2005 16:52:18
Nathan, Check the loader. If it is a 2010 loader it is not very good. The big cylinders take leather washers (cup shaped) which don't hold up well, especially if cylinder is worn on inside. As I have posted before, there is a wire mesh hydraulic filter on the RH bottom of the transmission case that needs cleaning perodically and new oil installed. After a while, the cleaner gets too clogged to clean an a new one is needed. My 2010 worked a whole lot better when I kept it out of the rain. If shifter causes trouble and is not too worn, the problem may be in adjustments under the LH foot rest. read manual. Never had trouble with PTO. Hydraulic pump just adequate for loader. Find out how long loader has been on tractor. Examine points of wear closely, look for cracks, patches, etc. Power steering gets priority(according to JD dealer) so if you are lifting an steering you may have problems. 2010 is heavy enough to handle loader if other things are OK. A rebuilt engine is a BIG plus, but check out everything else. A loader with the old cylinders like I described is not good, but I was thinking of aftermarket cylinders before I sold the tractor. Hope this helps your decision.
KEH
hbarnhardt
08-22-2005 15:21:54
Many years ago a construction company owner owed me $3500.00. He came to me and stated that he was broke, and wanted to know if I would take a 2010 as payment. He was a grand old man, so I said "OK". I've had the tractor over 15 years, and though I dislike the shifting mechanism (which is worn out) I've had very little problems. The tractor is now sitting with a bad starter. Its a pulling machine though.
