JD 4020 Diesel
Floyd
08-22-2005 13:29:24
Two questions I can"t find addressed in the service manual. 1968 4020 diesel. Tractor will not shut off. I have tried disconnecting the throttle linkage and manually pulling the throttle arm to the most rear position and it still won"t shut off. All adjustment screws apprear to be tight.
Fuel filter/s? Mine has the fuel line from the pump going to an aluminum block under a black box mounted in a friction clip type bracket. I can find no pictures of this type of "filter" in the manuals. Is it an add on? is it even a filter?
Thanks, Floyd
donmyeil
08-23-2005 12:39:39
 Re: JD 4020 Diesel in reply to Floyd, 08-22-2005 13:29:24
Sounds like the foot throttle is stuck down. Pull up on it and see if it stops then. don
twopop
08-22-2005 18:32:42
inside the cover on at the rear of the pump[the cover with 3 screws in it ] there is a u shaped clip that moves the throttle needle.if this clip has come off,the motor wont shut off.
msb
08-22-2005 16:01:44
If you have popped the linkaage off at the injection pump and pulled the lever back as far as it can go as you say you did, then there is only one thing I can think would be your problem.I suspect the govenor link has come loose and the link is out of adjustment.It takes a special go-no go tool to set the link.It would be VERY rare for that to happen,but it could,I guess.
One other thought; the govenor weight retainer seal has disintegrated and a piece of it is keeping the metering valve from fully closing.
In either case, the pump will have to come off.(DO NOT BEND THE INJECTOR LINES)Take them off,one at a time.
The filter you have is a MUCH better filter than the original one.
floyd
08-23-2005 06:10:27
 Re: JD 4020 Diesel in reply to msb, 08-22-2005 16:01:44
Thanks guys, for all the good tips and advice. I'll check out all the possibilities.
Floyd
HuskerMedic
08-22-2005 14:41:03
My great-uncle had a 1968 or '69 4020 that was pretty close to worn out. To get it to shut off, we had to put the hand throttle in the off position, then put our toe under the foot throttle and lift up. I was told this was a common problem with this series tractor, and had something to do with worn out throttle linkage.
Floyd
08-22-2005 14:43:30
 Re: JD 4020 Diesel in reply to HuskerMedic, 08-22-2005 14:41:03
Thanks, that is something I didn't try. I'm sure the linkage needs some attention too.
MSM
08-22-2005 14:16:09
The "black box"is the fuel filter.Older tractors were updated with this style fuel filter which came on the later model 4020's.Are you sure on the age of the tractor.Later console models used an electric fuel solenoid in the injection pump to shut off the tractor. I have had console tractors with a bad diode in the alternator(or a homewired aftermarket alt) which backfed the system and would not let the tractor shut off.Have also seen stuck solenoids,or plungers removed, which will not allow normal shutdown.Does your tractor have a single wire going to the injection pump?Is it an original tractor,or has someone "updated it" with a newer injection pump with another switch somewhere.
Floyd
08-22-2005 14:24:42
 Re: JD 4020 Diesel in reply to MSM, 08-22-2005 14:16:09
I am judging the year model by the tag/serial number on the rear housing. I have no history on the tractor, so modifications are possible, however it is a 24 volt generator and not an alternator. I do not have access to the tractor right today, so I can't respond to your question about the single wire to the injection pump. I'll have to get back to you on that one. This problem only started after a few hours of running a shredder. Previously no problem has existed. What is the procedure for changing the filter, just remove from the spring clip and replace, is it washable?
Thanks for you quick response, Floyd.
Tx Jim
08-22-2005 15:20:41
 Re: JD 4020 Diesel in reply to Floyd, 08-22-2005 14:24:42
Floyd,if your tractor is 24V don't bother looking for an electrical wire activating injector pump as it won't be there. Fuel filters aren't that expensive so replace your old one. Jim
floyd
08-22-2005 18:29:19
 Re: JD 4020 Diesel in reply to Tx Jim, 08-22-2005 15:20:41
Thanks Jim,
I just wanted to make sure what it is before I start taking it off since I couldn"t find anything like it in the manuals.
