JD 3010 Questions
Charles Beavers
08-22-2005 12:23:16
How much benefit will my 3010 get if I change the distributor to electronic (such as Pertronic)? Where can I buy the Pertronic ignition?
My carburetor is rebuilt and I installed new points, condenser and Autolite plugs. The engine seems to run fine except after it heats up to about 180 degrees it runs a little rough for about 7 minutes and then clears up. Is this normal??
When I rev up the engine I see (in the daylight) a white/brown smoke (maybe a tint of black) come out of the exhaust. Is this normal??
Thank you very much for your help...Charles
Douglas W
08-22-2005 21:40:43
 Re: JD 3010 Questions in reply to Charles Beaverson, 08-22-2005 12:23:16
Charles,
I've got a 3010 Lp that I switched over to - ground and put a Petronix ignition on. Mine runs quite a bit smoother than the points system. I see no drawbacks (yet), I would do it again. Surely it is more fuel efficient with electronic vs. points.
Roger Warhurst
08-22-2005 20:34:24
I am courious what a 3010 deseil is worth in good working order it seems to be a low profile tractor a freind of mine has one I was just courious to what it might be worth we are not sure what we have
Thanks for your help
Roger Warhurst
msb
08-22-2005 16:05:07
How are your heat riser blocks set? Hot or cold?
Charles Beaverson
08-22-2005 18:12:43
 Re: JD 3010 Questions in reply to msb, 08-22-2005 16:05:07
I should check my owner's manual, but I think they may be set for the cold
buckeye al
08-22-2005 14:25:09
Buddy of mine has two 2010's. One a loader/backhoe the other just an AG tractor. Put one in the Ag tractor. Started easier, better, idles better & behaves better all 'round. His was still original generator equipped model with + to ground so repolarization was in order but I guess + ground units are now available.
He likes his!
Later.
BradB
08-22-2005 13:58:36
Have a Ford 800 that I put the electronic Ignition on and it has been great. Not one problem. I would say go for it. Mine has been on for five years.
woodbutcher
08-22-2005 13:54:11
Charles,
I have a 3010, and I have considered replacing the points with the electronic ignition. Until mine warms up, it runs a bit rough. The conversion kits are listed under the parts tab at the top of this web page. I haven't priced them. I hope you get feedback from somebody who has done the conversion.
Butch
