How do I know when I need brake pads?
Charlie1520
08-22-2005 11:22:15
I have a JD1530 that the brakes will chatter when braking hard shortly before it comes to a stop. Is this a sign of worn brake pads or something else? It looks like I would have to pull the rear wheels to check the pads or is there an easier way? Thanks.
MSM
08-22-2005 14:26:58
 Re: How do I know when I need brake pads? in reply to Charlie1520, 08-22-2005 11:22:15
If the filter is clean(no brass,silver paste,large chunks) the brakes should be good. The use of some aftermarket hydraulic oils will give brake chatter. The use of a straight hydraulic oil will give brake chatter,and the possibility of brakes disolving. If the filter is reasonably clean,replace it,and drain the oil.Refill it with HyGuard or a GOOD quality,universal tractor fluid. The hyGuard/UTF have wet brake additives in it to help with brake chatter.
Mike M
08-22-2005 12:59:05
Look in your trans. oil filter for metal and in your suction screen for metal or lining material.
