Brake Noise, '49 JD A
ol' guy
08-21-2005 18:44:03
I'm looking at the '49 "A" with the idea of buying it, and drove it yesterday. When actuated, the left brake makes a terrible noise. The break fuctions alright otherwise. What's the most likely cause of the noise? I've had other 2-cyl JD tractors make a little of this same noise, but nothing like this one. Thanks for the help.
DickD
08-29-2005 18:56:33
 Re: Brake Noise, '49 JD A in reply to ol' guy, 08-21-2005 18:44:03
Back when this tractor was new, there were very few mounted tools used. If you were pulling a pulltype disc or other tools of this caliber and especially with a narrow front end, you really had to lean on the brake to turn. It is fairly simple to take out the 3 bolts that hold the brake on, and disassemble the brake to see if the drum is crystalized or if the rivets are rubbing the drum . May be a simple fix, if you really like the tractor.
Mike M
08-22-2005 05:56:01
That brake may be the least of your problems ! On those models look really, really close for a loose clutch driver,loose flywheel,and cracks on the bottom of the head and block.They also like to crack internal so look closely at the coolant level and work it some if you can.And if when it first starts up if it missfires then clears up if you can sniff any burt antifreeze or pull the spark plug and have antifreeze on it leave it set and look at another.
Joe S.
08-22-2005 04:20:42
As on mine it was metal on metal from the sound of you discription.
Dave in SV
08-21-2005 19:21:52
... hard to tell without "hearing it" for myself. I had problems with mine ('49 A), and found excessive oil (?) on the shoes and seized up adjusters. After a thourough cleanup and replacement of linings, all seemed OK again.
