4020 GAS (NEED HELP)
GREG RUSHING
08-21-2005 08:27:17
I have a 4020 gas powershift with electronic ignition, and I bought a used supposedly re-built MARVEL-SCHNEBUER carburator to replace the original M-S carb.I installed an in-line fuel filter when installing the new carb. My problem is tractor cranks fine and runs great for a while, but under load it starts skipping really bad, especially notice going up hill. If I stop, the problem will go away & smooths out, but will start again under load. I know I should bite the bullet and buy a zenith from other post read here. Any suggestions would sure be appreciated. It seems its not getting enough fuel.
Mike M
08-22-2005 05:35:16
 Re: 4020 GAS (NEED HELP) in reply to GREG RUSHING, 08-21-2005 08:27:17
First off I'm going to scold you for buying another carb. and not upgradeing to a Zenith !
Now that you have another MS try opening up the LOAD adjustment to let more fuel in when you start pulling up that hill,these tractors need lots of fuel !
Jim in AK
08-21-2005 23:05:55
I had a similar problem with another machine. Was checking out rebuild kits when the NAPA man suggested a poor in the tank carb cleaner, less than $5.00. I got it and it cleared the problem up immediately. Seem to have been a gummy carb float valve from setting all last winter. For me that turned out to be a fast and cheep fix.
Jim
bryan s
08-21-2005 18:16:42
dont over look a possible bad condenser or too far advanced timing-ive seen these to be the problem w/similar syptoms on the dyno
hlc
08-21-2005 14:28:06
I think your problem might indicate the fuel mixture is too lean. I had this problem once on a different machine and after the carb was set a little richer everything was ok.
Huckleberry
08-21-2005 13:32:36
Probably unlikely you would have same problem...but on a 2520 gas I was once baffled, trying everything [except a different brand of Carb, my marvel worked fine] until I finally removed the gas tank and shook it up and down. A large thumb size beetle fell out. How it got there? was maybe lounging in the nozzle? who knows...anyways tractor performance was greatly improved.
SMA in NE
08-21-2005 09:27:26
I have a 4020 gas with the M/S carb. I have cleaned it and installed a new needle/seat and diaphragm. The tractor runs very well with this carb. I put up 150 acres of alfalfa this year and do a little custom haying. I pull a 16' windrower, a 12 wheel rake, and a JD 535 baler. I am about half done windrowing 4th cutting now. The M/S carb can work with proper adjustment in my opinion. Maybe your mixture is too lean, the float is set too low, or you have a restriction in your fuel line. I wouldn't give up on your carb just yet. My 4020 uses between 4.5 and 5 gal of gas windrowing, probably a little more baling because the baler works it a little more. Good Luck
Mike M
08-22-2005 05:42:09
 Re: 4020 GAS (NEED HELP) in reply to SMA in NE, 08-21-2005 09:27:26
Sounds like you are running at a more constant engine speed and under a load most times. My MS carb. worked ok in these situations too. I mainly do loader work,alot of idling and back and forth speed up and down all over the place on and off load all the time. This is where that MS carb. drove me nuts as I think the acceleration design is not nearly as good as the Zenith.
Bob
08-21-2005 08:32:53
You might try "tee'ing" into the fuel line at the carb and connecting a low pressure gauge to verify that there is adequate fuel pressure to the carb under load conditions. Lack of pressure there would indicate a restriction in the fuel system.
