4240 AC problems
vrickster
08-20-2005 04:27:12
In the past 2 years I have had 3 ac compressors go out. The last one lasted only 1 month. The thing abruptly starts making a loud grinding sound and quits the moment I turn off the AC. I have had the same shop do the work every time. They just keep tellng me, "The compressor was bad", and install another. Does anyone know what the heck is going on? What kind of questions should I be asking the shop? Thanks everyone.
Jim in AK
08-21-2005 23:17:28
 Re: 4240 AC problems in reply to vrickster, 08-20-2005 04:27:12
I got 2 years in trade school and 23 years in the AC field. You need to find a better AC service man.
Jim
rotten robert
08-20-2005 13:00:42
The filter/dryer is located at the left rear ROPS post of the cab. If that has not been replaced each time then theres your problem. As mentioned a good flush of the ENTIRE ststem is called for. With that many failures you may want to consider replacing the condenser as well. A proper flush means opening every join in the lines and flushing both ways.
Henry J
08-20-2005 11:45:47
 Vacuum pump in reply to vrickster, 08-20-2005 04:27:12
A freebie vacuum pump for me has always been a compressor out of a discarded frig or dehumidifier. They are slow but will pull down 18 inches if still in decent shape.
cannonball
08-22-2005 05:02:58
 Re: Vacuum pump in reply to Henry J, 08-20-2005 11:45:47
18 inches won't do anything..need 28 ...have nice day may god bless
Glen in TX
08-20-2005 10:50:05
I agree with Robert about going to a different shop. Anytime a compressor blows out it will leave crud in system plugging the expansion valve orfice and screen and the dryer filter. Can also plug the inlet screen at pump. A flush and drier replacement should be done after a pump failure. If they don't do that find someone else that does. Flaking of old hoses can cause plug ups also. You should get several years out of even a rebuilt pump is job is done right. I always had better luck with the JD rebuilt pumps than the local auto supply ones. The JD Fundamentals of Service Manual FOS5707B is excellent source of info on air conditioners if you want to learn but you will have to invest in tools and proper equipment also like a vaccuum pump or borrow or rent one.
vrickster
08-20-2005 14:47:12
 Re: 4240 AC problems GLENN in reply to Glen in TX, 08-20-2005 10:50:05
I am in Lockhart, TX. 20 miles south of Austin. Are you close to me? I checked on line and none of the dealers have this FOS5707B manual. I went out and checked and sure enough, the filter/dryer was NOT replaced. The AC is working fine right now but from what you all say, I don't expect it to last a week. I am very mechanical, just have never had the need to work on AC. I am ready to learn all about it before this one goes out again. you can email me direct at acard at texas dot net
Glen in TX
08-20-2005 19:00:51
 Re: 4240 AC problems GLENN in reply to vrickster, 08-20-2005 14:47:12
I saw too that they don't show a price or availability of the FOS manuals online. FOS-5707B was the air conditioning manual listed for 1994 year. The other FOS manuals are not listed either but can call 800-522-7448 to find out or ask dealer too. FOS-5705B covers 30 & 40 series. FOS-57B Air Conditioning covered the earlier 20 series and SM-2089 covers others 4000 thru the 7520 with Stolper and Hinson cabs.
Glen in TX
08-20-2005 16:09:11
I may have got the wrong number of manual? Will check it later and email you. I'm up in the panhandle SW of Amarillo. JD may even have some new better manuals now but this one I have is the one that a JD mechanic gave to me to learn with and it's explains AC theory and repairs well.
robertq
08-20-2005 04:52:08
I would go too a different shop !!!!!,tell them the history.It will cost though.You will need a new dryer,and redo expansion valve,if it acts up intermitantly your pressure goes too high and kills comp.,demand total flush,as system will be full of junk and too much oil etc.Also make sure you have high and low safty switches that WORK.
Henry J
08-20-2005 07:43:26
 Re: 4240 AC problems in reply to robertq , 08-20-2005 04:52:08
Additionally, after so many compressors eating themselves, I would recommend the installation of an additional filter. It has been a long time since I dealt with such a problem on a car so i can't remember exactly where the filter is supposed to go.
