820 hyd.
irving
08-19-2005 16:46:42
pump will not pick up lifting arms until tractor has run for say 20 min. then pump screams in short bursts like it is not getting fluid. fast enough have changed filter and fluid already.any help would be greatly app.
Tx Jim
08-20-2005 03:48:45
 Re: 820 hyd. in reply to irving, 08-19-2005 16:46:42
Irving,if it's a 3 cyl. did you clean sump screen in bottom of trans.? Jim
Irving
08-21-2005 15:04:25
 Re: 820 hyd. in reply to Tx Jim, 08-20-2005 03:48:45
no Jim but Im not sure where that is forsure.
irving
08-28-2005 14:52:34
 Re: 820 hyd. in reply to Irving, 08-21-2005 15:04:25
cleanout sump screen seemed to help some but still the pump out front seems to scream like it is not getting enough fluid
irving
08-28-2005 14:52:34
cannonball
08-22-2005 05:09:27
look for a round plug with a square 1/2 insert, you will loose all the fluid, i use a tub to catch fluid, if screen is dirty you may have brake problems starting..have nice day may god bless
