JD 420 Hydraulics questions
Craig-MN
08-19-2005 15:12:58
Someone asked me to look at their John Deere 420 tractor, serial above 125,000. The rockshaft does not work and there is a lot of vibration or chatter in the hydraulic line over the fuel tank to the pump. The story I was told about this tractor is that the original owner disconnected the rockshaft hydraulics and only had a loader connect the the hydraulic pump. Supposedly the rockshaft and 3-point hitch was never used. Anyway, the present owner disassembled the Touch-o-matic hydraulic stuff and put it all together again. I suspect he messed up something inside. We have an I&T service manual and the operators manual. However neither of those show a schematic of the hydraulics for me to study and understand. Where do I start with troubleshooting this thing?
buckeye al
08-22-2005 15:48:15
 Re: JD 420 Hydraulics questions in reply to Craig-MN, 08-19-2005 15:12:58
I must tell you I have not been in a 420 but about 2 years ago, restored the dual TOM on our 40 two row utility and I ASSUME they're similar. If not, consider me all wet!
For the plumbing.... On the 40, the pump sucks oil (or should) out the lower left rear of the rockshaft housing of the TOM. Oil returns from the pump to the TOM near the top left of the unit. Ports are of significant difference in size. If reversed I'd think the pump would be running dry unless the unit was REALLY full of oil but I 'spose it's possible! At the very least if reversed, the pump would be starved and growling. By all means check the plumbing. With open center, oil can flow both ways if the level is high enough. We use Hygard in our since the re-build but it does not lift as much as it did with 20 wt. I suspect the pump clearances are causing this.
Agree, don't really think it's the pump as you've heard the load it puts on the engine through the remote valve.
The remote valve mechanism has a relief valve in it to prevent pressure damage when remotes reach the end of stroke or the operator holds the lever in operate position. This is a relief valve JUST for the remote and is in the remote valve body. The TOM rockshaft operation has relief valves inside, one for each cylinder. They may be stuck open or improperly assembled though these are fairly trouble free.
The TOM units are open center & all oil from the pump just dumps back into the reservoir until you tell it to move a rockshaft. The valving that takes place to cause the units to raise is that the operating lever you move, moves a rod and the rod closes off the bypass port to the reservoir. The oil is then backed up and since it has to go some place, it is diverted through the check valves into the lifting cylinders. A cam on the rock shaft changes the position of this valve rod as the rockshaft moves. Once to the right position, the rod is moved re-opening the bypass hole & the pressure is gone with all oil dumping back into the reservoir. The check valves hold the oil in the lift cylinders to hold position. Lowering is accomplished by a ramp in the side of the rod that is brought into contact with the stem of the poppet type check vave & lifts the check off the seat to let the implement down. Again, as the cam on the rock shaft moves, the followers change the rod position and the ramp moves away from the check valve stopping the release. The implement is held in this position.
Short story... Unless it's a plumbing problem (first check) you probably won't know until you remove it but... It could have a broken follower spring or springs though I if I remember right, if one breaks they both become disabled. It then won't do squat! It could have improperly installed followers or the linkage is assembled incorrectly or the internal relief valves could be the trouble. My bet is the springs, the followers or wrong linkage assembly. In any case, unless it's a plumbing problem, it has to be removed!
Good luck. Post back with what you find!
Craig-MN
08-22-2005 20:41:28
 Re: JD 420 Hydraulics questions in reply to buckeye al, 08-22-2005 15:48:15
Thanks for the info. This is the closest I've been to a 420 since I was 8 years old (that was over 30 years ago). The present owner said he removed and disassembled the TOM unit and I suspect he did more harm than good. I also need to check those hoses he installed, the fittings may have a small hole through them that restricts oil flow. There is an awful lot of noise and chatter in the system with it just running under no load.
He also put #30 engine oil in the system. Will this matter? I thought the book said 10W.
jp24a44
08-23-2005 10:18:00
 Re: JD 420 Hydraulics questions in reply to Craig-MN, 08-22-2005 20:41:28
Too heavy of an oil will definitely cause problems. The pump won"t be able to generate enough pressure to open the check valve and get oil behind the cylinder heads.
I think someone else already recommended it, but flush the system with kerosine (deisel fuel will work as well) and fill with SAE 10W Hydrolic oil. It needs to be non detergent and non-foaming.
While your looking at plumbing... too large of a pressure hose will cause a drop in pressure as well. The pressure line should be 1/2" ID.
I"m in the process of doing this now on my 40... I"ll let you know what I find.
buckeye al
08-23-2005 14:14:49
 Re: JD 420 Hydraulics questions in reply to jp24a44, 08-23-2005 10:18:00
YES the heavy oil will make noise. Especially if the suction line has pin holes (leaking air in) in it up under the hood. Because it's down hill from the line back to the TOM unit, air leaks can develop in the lines and oil not leak out because it's a suction line.
We use Hygard just like in the 4020.
jp24a44
08-21-2005 12:42:14
Must have been the same guy that put the loader on my 40 as I have a similar problem... My rockshaft doesn"t do anything either. The steel lines were replaced by hoses (the return actually looks like to large of an ID).
I drained the system and filled it with new fluid.
There"s pressure in the system, but maybe not enough?
Here"s the odd part... with the throttle wide open, and the control lever in the "lower" position, the rockshaft tries to lift the arms. In the raise position, I get nothing.
There aren"t any leaks in the system, because if I raise the arms by hand and hang an implement from it, they"ll stay up all night.
I pulled the ispection plugs, and I"m getting fuild past the bypass valve and passed the check valve.
I"m at a loss... stuck check valve maybe? Or an incorrect relief valve setting?
Anyone have any ideas? Craig, if you figure out your 420, let me know...
-Jason
buickanddeere
08-21-2005 05:22:53
For dual rockshaft operation the outside leve has to be help all the way up. The valve pins have to be out if memory serves. The inside lever does all the rockshaft control. Odds are when working blind with the useless IT manual. Both the hydraulic lines and lever operation is messed up. If the tractor has had those pins in for years. They may not spring out on thier own for single rockshaft operation. 1st things 1st. Throw that IT manual away and get the real thing. 1-800-522-7448. Somebody using hoses rather than bothering to find the proper pipes sounds like someone prone to taking shortcuts. Some goes for who ever tinkered the loader on. It's easy to leave the rockshaft and remotes if they exist, in operation.
Henry J
08-19-2005 18:09:11
craig
you are dealing with a legend here. If it was a loader tractor and the owner did not have it plummed like the loader manual says, I would say that the first thing to do it to make sure that the plumbing is correct for the pressure and suction.
is this a for sure thing?
Craig-MN
08-19-2005 18:38:15
 Re: JD 420 Hydraulics questions in reply to Henry J, 08-19-2005 18:09:11
The guy who has it now has intalled hoses in many places that originally would have been steel tubing. I don't know if he has it plumbed right or not. A little more explanation I forgot in the first post.... There is a knob on the left side of the hyd valve housing that selects independent or unison operaton of the rockshaft. If it is set to hold in the two valve pins then we get some movement out of both rockshafts. With it unscrewed and both valve pins out there is no movement at all of rockshaft. This tractor also has the remote hydraulic outlet and when operating the lever for that in either direction it pulls the engine down so that says the pump is pumping oil. With no lever activated the engine has no load but there is a lot of vibration and chatter in the hydraulic lines to the pump. I do not know which line is in or out or where they go. I really expect I need the factory service manual with some hydraulic schematics.
DeereGuy
08-19-2005 17:33:06
A 420 or a 4020? I'm not familiar with the 420's, but on a 4020: I would start by seeing what the main pump pressure is. The I/T manual says you can check it where the brake lines hook to one another just inside the cubby hold where the ignition key etc. is. I just recently had to do this myself, and inquired about where to find a high enough psi gauge. (The tractors are capable of producing up to 3000 psi, you should always be very careful). Anyway, some guy on this site directed me to
Link
Craig-MN
08-19-2005 18:39:53
 Re: JD 420 Hydraulics questions in reply to DeereGuy, 08-19-2005 17:33:06
It is a 420 tractor. Not 4020.
CPeter
08-20-2005 18:56:46
 Re: JD 420 Hydraulics questions in reply to Craig-MN, 08-19-2005 18:39:53
I have a 420U with the 3pt and it is basically an open center hydraulic system. Yours is also, but has the option of the live hydraulics to the real and as I understand it, one c=had a loader hooked in somewhere. There are two lines to and from the hydraulic pump. The larger one from low in the TOM unit is the suction line TO the pump. The smaller one is the pressure line FROM the pump to the TOM. you need to follow the flow to determine what position the other control valve is supposed to be in. Bad seals in the suction line can cause chattering and loss of pressure. There are a common source of problems. Also the oil used should be 10wt NON detergent or a very thin hydraulic oil with a good anti foaming agent. You might want to try flushing the system with kerosene and see if that helps. If it does, you might have had too heavy oil or water/oil in the system. Did you check the oil level in the TOM?
CPeter
