420W starter
Bill
10-25-2003 20:23:24
The starter drive teeth get chewed up on this I have replaced it 3 times the flywheel is in good shape. The last drive I put on I ground off the end of the nose of the gear and rewelded to drive to get better engagement w/flywheel, this procedure lasted longer but still failed. Any thoughts would be appreated.
Wayne in Tn.
10-26-2003 09:02:48
 Re: 420W starter in reply to Bill, 10-25-2003 20:23:24
Bill, the 420-430 models seem to have a problem chewing the drive teeth up. If you have a 12 volt battery, that may be harder on the drive. After what you have said, it would seem possible there is some damage to the flywheel ring teeth. Also there is supposed to be some washers to limit the travel of the drive, on the end of the starter shaft. If nothing else, you may have to break her into and install a new flywheel ring, and new starter drive. If you have access to one, I would try another starter also. I have seen those things slam so hard with 12 volts, that they will break the starter nose housing.
Henry J
10-26-2003 04:32:00
Bill
Please disregard my post. I meant it for Joe for the rings. Twas a senior moment lol.
Henry J
10-26-2003 04:30:18
Hey this is getting to be a challenge. The Number is blocked. Lets see if 1-*888-*828*-3276* will post.
R. Marg
10-25-2003 21:52:48
is the flywheel out of round or bent either one of those things would mess up a starter drive hope this helps some
