3010 D sleeves and Oring groove that is pitted
Lstallbaumer
08-18-2005 20:06:07
third party image
I have a 1963 3010 D that started leaking past the orings and into the crank case. I caught it and did not damage the crank but the groves in the block are badly pitted. How do you repair them.
History of tractor. It was built in 1963 and apparantly in 1968 (numbers on rod Bearings) was taken apart and three orings were installed and new rod bearings. The gent that owned it was my neighbor and he bought it to farm but his machanics bussiness took off and rented his ground out and the tractor was used seldom until 1999 when I bought it. When he owned it the tractor sat outside a lot of the time because his shop was full until the mid 70s. I purchased it in 1999 as a colectors piece / toy and painted it becuase is sat outside alot those years. Anyway now I have put another 90 hrs on it in the six years and it has 1100 hours on it. I was amazed to see the you could still see the hone marks in the inside of the sleves, no ring groove at all. But the ouside of the sleeves were bad, real bad, the electrolisys had nearly eaten all the way throught the sleeves in a few spots. I am installing a new 3020 kit in the tractor but I need to correct the problem with the block. I do not farm but grew up on a 3010 identical to this one. I know you can take the block out and have a new machined oring section installed. To be realistic I would not expect to use it any more than I have in the last 6 years and at that rate when I am 65 the tractor the tractor with be 66 years old and will have 1500 hours on it.
Anyway do not want to spend too much more but would like it to last at least 10 years or 150 hours.
Thanks
Lynn Stallbaumer
Sabetha KS
joe bular
08-21-2005 17:33:48
 Re: 3010 D sleeves and Oring groove that is pitted in reply to Lstallbaumer, 08-18-2005 20:06:07
Sorry to be late with a reply.
Take that block to a good machine shop who does boring. Have them bore out where the o-rings set and dry sleeve that area. They will cut down a sleeve to the length needed ang press in, it will have to be finish bored and give a little chamfer on top so not to cut o-ring. I have had this done many times on Deeres and ACs, 6 cly. cost around $150.00 for all. Tried liquid metal it only patchs the problem till the next poor soul gets it, you can never get it clean enough to hold for very long, will rust under the patch and come off.
3010 Ken
08-19-2005 04:53:04
Morning Mr. L;Wow that is a nice tractor.Wish mine looked that good.Thanks for the pic.I'm glad you posted as I plan to do the same thing to mine this winter with the engine.I will be looking closely at those grooves in my block.My tractor shows all the earmarks of being ridden hard and put up wet.That old motor is tired and I'm looking forward to seeing how it runs when it is fresh.Good Luck with yours! Kenny
JD 4020 3020 620 420
08-18-2005 20:49:44
I would concider adding a third o ring to be sure it seals. The other suggestion is a good one, but this is just a extra caution. I believe the 3010-4010... has 3 grooves in the block and the sleeves, just like the 3020-4020. The center groove is the one with the weep hole. Plug the hole(many ways to do this, but tapping and screwing in a plug is the best. Then install a third o ring in this groove. I have a 64 4020 that was just overhauled and had this done because one o ring groove had a chip missing out of it. No problems so far and the mechanic said he has been doing this "fix" for years without any problems yet. Good Luck! hold on to that tractor as long as you can!
Roy Suomi
08-18-2005 20:26:29
I've done several industrial engines with the same problem. If you have the time and patience, You can try a little liquid steel on the land thats eroded. Fill by hand, sand , and sand some more. But watch that you don't raise the liner height in the block..
LStallbaumer
08-18-2005 21:13:13
 Re: 3010 D sleeves and Oring groove that is pitted in reply to Roy Suomi, 08-18-2005 20:26:29
Liquid steel is that like JB Weld?
Thanks
Lynn
Roy Suomi
08-19-2005 19:29:55
 Re: 3010 D sleeves and Oring groove that is pitted in reply to LStallbaumer, 08-18-2005 21:13:13
Yeah. It's all the same stuff. I once saw a man use a product called Belzoa on a Ford 550 backhoe swing frame main bushing. It stayed in there for years. Don't know where Belzoa can be bought, I think through a specialty salesman..
