JD 2-Cyl Main Bearing oil flow...
BushogPapa
08-18-2005 20:04:43
I had to replace the Rt side Main Bearing and rod bearing in my JD 630 this summer... $135.00 plus $51.25 Machining cost..for the Main, alone..
After tearing the Main Caps off, I see that the "O" rings that seal the Main oil gallery to the outlet in the main case had "cold-flowed" into the passage and cut off oil flow... I am offering this as a Warning...CHANGE these "O-Rings"....even though it is a lot of work...!!! Has anyone else seen this as a prominent problem..???? The O-Rings and gaskets are not expensive..just all the time to drop the flywheel, and 1st reduction cover...right brake, and rt rear wheel..!! Does anyone know if this is a problem with most ALL 2-Cylinder JD's..???
Thanks..!! Ron..
Mike M
08-19-2005 03:56:07
 Re: JD 2-Cyl Main Bearing oil flow... in reply to BushogPapa, 08-18-2005 20:04:43
Was that an LP tractor ? And if so I wonder if some additive to LP caused this ? LP is supposed to affect rubber hoses and your to use special ones. As many of those tractors still running around many still untouched in the mains and crank area it must not of been very common.I would of thought that they would harden up and get brittle,at least that's what I have seen on the few rubber parts on those later 2cyls.
BushogPapa
08-19-2005 21:05:53
 Re: JD 2-Cyl Main Bearing oil flow... in reply to Mike M, 08-19-2005 03:56:07
Nope..this is a Gasoline 630....
The O-rings have "Puckered" toward the oil hole, and the "best" one was on the flywheel side and you could not get a pencil lead to go thru it..!!
The clutch-side was virtually completely closed..
This engine still ran fine..except fot the Rt Main seal leaking into the 1st reduction case...the main had partially spun and closed off the oil hole completely in the main bearing..the main measured a clearance of .055" the crank was not damaged..!! I will make it a policy to pull the mains on any non OVERHAULED 2-cylinder JD's I rebuild from now on..!! How many out there are ready to loose a main bearing..?? I bet Plenty...!!
Mike M
08-20-2005 10:31:54
 Re: JD 2-Cyl Main Bearing oil flow... in reply to BushogPapa, 08-19-2005 21:05:53
Yep,nothing beats tearing one down and checking everything ! After all those years you can find lots of problems needing fixed if you just look.
