2950 charging problem
Mapleridge
08-18-2005 19:35:20
I have a 2950 with a charging problem. It was working fine then the alternator quit charging. I got another from NAPA, same one, but it didn't charge so I brought it back. Next one did the same thing. Probably burning up a diode in the internal regularor for some reason. Something is wrong to kill these so quick. The system only has a key switch a light switch and the starter so I am having a problem trying to figure out what is going on. Batteries are about a year old and there is voltage to the alternator. Any hints? I tired of parking it on the hill.
Thanks
cannonball
08-20-2005 06:48:07
 Re: 2950 charging problem in reply to Mapleridge, 08-18-2005 19:35:20
are you replacing the alt with same brand..what did it come with...i replaced a 2840 with a one wire delco because they wanted more for a voltage regulator than the one wire cost...changed a 4040 to a delco had to change wires on plug in..swap then around.....have nice day may god bless
buickanddeere
08-18-2005 23:30:14
Are the batteries completely discharged and the alternator trying to charge them? Any shorts in the wiring harness? Has somebody been tinkering with the wiring harness?
