Differences between L and LA
tyler-mo
08-18-2005 09:11:07
If anyone can give me some of the basic and easily told differences between an L and LA tractors it would be much appreciated. I"ve tried the JD parts books and can"t find an easy difference. I know that the L tractors that I"m looking at are styled. Thanks in advance....
Tyler in Missouri
DickD
08-18-2005 11:59:55
 Re: Differences between L and LA in reply to tyler-mo, 08-18-2005 09:11:07
I restored an"L" last year, and bought an"LA" for parts. Big mistake. The front wheels were too deep on the "LA" to fit the "L". The rear wheels on the "LA" are cast centers with bolt on rims, while the "L" has one piece pressed steel rims.
The transmissions were different. These were both 39 models.
Deeredale
08-18-2005 20:53:25
 Re: Differences between L and LA in reply to DickD, 08-18-2005 11:59:55
The LA did not come out until 1941. The transmission was different on the 39 Ls but was then changed to be the same as the LA in 1940. The front wheels were the same on all the L series except for the wheels you had. The were what as known as "deep dish" or "popeyed" front wheels. There were use mainly in the south to narrow up the tread width.
The easiest way to tell the difference of the L & LA is naturally the serial tag. Since most of them are missing the next way is to inspect the rear wheels. The LA had a heavy cast iron center with a Cub style bolt on 24" rim. The Ls & LIs had a 1 piece pressed steel 22" rim. Don't be shocked if you find the L where the rims have been change to either 20" or 24" due to 22" tires not being made for several years back in the 60s & 70s. You will also find many Ls that the rear wheels have been changed to old truck wheels. Rarely do you see the happen to the LAs.
I have pictures of both on our web site below.
DickD
08-18-2005 11:46:54
I redid an "L" last year and bought an "LA" for parts. Big mistake. Transmission was different, the front wheels on the "LA" are deeper and won't bolt on an"L", the rear wheels on the "L" are one piece pressed steel, where the wheels on the"LA" are cast with bolt on rims. I am sure there are more,but these were some I witnessed
Mike M
08-18-2005 09:51:48
L has a thin wall frame looks like normal pipe tubing and has all steel rims. LA has either a solid frame or one with a small hole through the center leaving about 1/2" or more wall thickness and they have cast iron centers that hold the rims.
