4010 sterring issues
H2
08-18-2005 07:32:30
My 4010 will not steer to the right at times. It will work <
br>just fine and all of a sudden it will act up. If I hold the
steering wheel as if turning to the right the wheels will eventually turn. Also if I am running the loader at the same time that I am steering [in either direction] steering is interrupted.
donmyeil
08-18-2005 13:07:48
 Re: 4010 sterring issues in reply to H2, 08-18-2005 07:32:30
You need to overhaul the steering motor. The o-rings have worn and loseing trapped oil. While you use the tractor you keep turning to the right to keep wheels straight, then the steering valve piston bottoms out opening the syncronising valve and then the wheels turn to the right. Hope this helps. Don
MSM
08-18-2005 09:28:43
You could have an internal hydraulic leak which interupts flow to the steering valve,a bad priority valve not directing flow to the steering ,improperly plumbed loader,clogged filter,bad loader valve or remote. Steering acts that way when it needs to be bled. You can possibly bleed it and it may work for a while,but the hydraulic problems will have to be addressed because as soon as you lose hydraulic flow,the steering will become airbound again.
