630 john deere clutch is not releasing
reynolds
08-18-2005 07:10:58
My 630 clutch worked fine but due to certain circumstances it had to set outside in the weather. it still snaps in and out but will not release. You have to pull the clutch back and hit the brakes to stop. I have tried adjusting it out and that made it slip. When you through the clutch in gear with it in neutral so the pully runs when it snaps out you have to push hard on the clutch and it wants to smoke. Could it just be rusted? Thanks
buckeye al
08-19-2005 15:14:04
 Re: 630 john deere clutch is not releasing in reply to reynolds, 08-18-2005 07:10:58
I notice all the other good advice but one item I see missing is the three springs that push the pressure plate away from the pulley. If they're rusted significantly they will not push the plate away from the pulley releasing the floating disks & plates. My 70D did EXACTLY what you describe.. One spring had broken and all were well rusted from many years of service. For the cost and safety make sure they're good and if not replace them!
Check those springs!
Maark
08-18-2005 11:39:34
You need to leave the clutch adjusted for proper operation, but you will need to adjust the clutch brake so that it will disengage. You can search archives for that adjustment procedure.
Mel in SW Iowa
08-18-2005 20:40:53
 Re: 630 john deere clutch is not releasing in reply to Maark, 08-18-2005 11:39:34
Reynolds,
Your clutch plates are rusted inside of the pulley. Pop the cover off, pull the cotter keys out of the three adjuster bolts, take the nuts and washers(I use one good grade 8 lock washer under each adjuster nut) off, pull your outer pressure plate ring, a friction floater, a splined
steel floater, etc. Remove all rust from steel
friction surfaces and reinstall. You will be glad you took the time and avoided a dangerous situation. Your clutch will work as its intended for much longer. Make notes of how many threads are showing outside of each adjuster nut to put you back in the ballpark with clutch adjustment.
Mel
Reynolds
08-23-2005 17:46:48
 Re: 630 john deere clutch is not releasing in reply to Mel in SW Iowa, 08-18-2005 20:40:53
I just got time to work on the old girl. Took every thing out and cleaned them up good. Works better then before thanks for all your help.
Reynolds
buickanddeere
08-19-2005 13:24:22
May as well clean and lube the bearing too while in there. The dogs, pins and toggles should be cleaned up and checked for wear.
buickanddeere
08-19-2005 13:24:18
