Front Wheels - Duane Larson
Shawn Slyter
08-18-2005 05:09:25
Duane,
I have seen that you are the local JD wheel expert! I have a 1946 A with the R 1262 front rims. Do you know where I can pick up a set of these?
Thanks,
Shawn Slyter
Duane Larson
08-18-2005 07:02:20
 Re: Front Wheels - Duane Larson in reply to Shawn Slyter, 08-18-2005 05:09:25
Shawn,
I've studied wheels for several years, but I don't consider myself an expert....
JD used JD1262R pressed steel reversible front wheels on B's - they are for 15" tires. Your A most likely came with JD1268R pressed steel reversible front wheels for 16" tires. There were a bunch of 1268's made and most JD parts vendors have some for sale. JD1268R is stamped in the pressed steel, so they are easy to identify (unless they have been painted many times). I'm sure there will be a selection at the Portland, IN show next week.
Pete/ME
08-19-2005 02:36:19
 Re: Front Wheels - Duane Larson in reply to Duane Larson, 08-18-2005 07:02:20
I've got a pair of 16" round spoke cut-offs I don't need. Are they worth anything? I don't mean money so much as usefulness to anyone.
Shawn Slyter
08-18-2005 07:07:40
Duane,
Thanks for your response! So obviously, sometime before we got the A in the early 80's someone switched the rims out, because I can clearly read the 1262R number on the rim. Hmm, maybe now is a good time to switch back to the 16's, since the 1262's are slightly bent and need to be replaced.
Duane Larson
08-18-2005 07:20:34
 Re: Front Wheels - Duane Larson in reply to Shawn Slyter, 08-18-2005 07:07:40
Shawn,
Well, to be sure, your 1262's should have 15" tires - and A's have 16".
Shawn Slyter
08-18-2005 07:24:29
 Re: Front Wheels - Duane Larson in reply to Duane Larson, 08-18-2005 07:20:34
Duane,
I will check tonight, but I am positive that they are 15". Also, what do you think is a good price for the rims? I have found a place (Sharp's) they have the 1268's that have been rerimmed for $99 each. How is that for a price??
Thanks,
Shawn
Duane Larson
08-18-2005 08:28:25
 Re: Front Wheels - Duane Larson in reply to Shawn Slyter, 08-18-2005 07:24:29
Shawn,
That seems like a fair price for re-rimmed wheels. Ask Melanie to make sure the centers and the bolt holes are in good shape. Most likely they would be fine as they have a good reputation.
At a swap meet you can probably find them cheaper, but they will often require work on the rims.
8e3k0
08-18-2005 11:33:06
 Re: Front Wheels - Duane Larson in reply to Duane Larson, 08-18-2005 08:28:25
Good used straight JD1268R rims run from $25 to $45 each depending on the area your in. I have bought good rims at Auctions for $25 each and also found good rims at Salvage yards for $50 negotiated for a pair.
