4020 hoods. Are they the same across serial breaks
Nylon
08-17-2005 22:06:07
Are 4020 hoods the same between the below 68 and above 69+ models?
Thanks,
John
G/MAN
08-18-2005 07:37:14
 Re: 4020 hoods. Are they the same across serial br in reply to Nylon, 08-17-2005 22:06:07
Tx Jim is correct. Difference in muffler holes. And JDBert is also correct. The new hoods from Deere are "blanks", and have to have the proper holes cut in them. I can't say for sure, but I assume they come with some sort of template for positioning the holes and cutting them to the proper dimensions.
JDBert
08-18-2005 11:46:31
 Re: 4020 hoods. Are they the same across serial br in reply to G/MAN, 08-18-2005 07:37:14
No Templates G/Man, My guess would be deere does this so they can make 1 hood for diesels, gas LP's and tractors that have had a different motor in them. I need to find someone that can do the hole AND put the curved edge on, dont know if its possible or not, but I dont think I would like to not have the lip, as I would think that the hood would be week with a big hole and no lip.
G/MAN
08-18-2005 13:52:39
 Re: 4020 hoods. Are they the same across serial br in reply to JDBert, 08-18-2005 11:46:31
Refresh my memory on the rolled edges, since I haven't look closely at a New Gen hood in a while. Which holes have the rolled edges? I don't think it's going to affect strength, as I don't think the newer hoods have a rolled edge around any of the holes.
Jason Z in MO
08-18-2005 15:27:24
 Re: 4020 hoods. Are they the same across serial br in reply to G/MAN, 08-18-2005 13:52:39
I have a new hood on one of my 4020's it was installed before I bought it. Its an early 4020 with the round muffler. The hole was cut by hand and the edges are not rolled. Its not a prefect cut but most people wouldn't notice it. I don't see a problem with strength.
The hood looks really nice after several years of hay work.
JDBert
08-18-2005 14:58:20
Just the muffler. all the other holes are there, I think theres even a punchout or a marking for vertical air stacks.
G/MAN
08-18-2005 15:37:46
 Re: 4020 hoods. Are they the same across serial br in reply to JDBert, 08-18-2005 14:58:20
I wouldn't sweat the rolled edge. Even the big-boy hoods, like the 4640, 4955 and so forth don't have a rolled edge around the muffler hole. And I've never seen one of those cracked in that area, after working on countless numbers of them. I'd have the hole punched using whatever means will produce the best results, give the edges a good deburring with emery cloth or sandpaper, and forget about it.
TIMAR
08-18-2005 08:04:25
They do not come with a template, and I have not figured out a way to get the finished rolled edge on the hole. Anyone else tried?
JDBert
08-18-2005 07:29:52
If your get a new hood from deere they have no muffler hole cut in them. I think they run about $1500.
Tx Jim
08-18-2005 03:52:00
 No in reply to Nylon, 08-17-2005 22:06:07
early model round muffler hole,late oval hole Jim
