JD 60 Hyd Question
Bobl1958
08-17-2005 10:41:08
I have a 1954 60 with an 801 3-point hitch. I would like to use a remote cylinder as well. I see where there are two 90 degree elbows coming out of the side of the pow r trol with pipe plugs in them. The pow r trol blank plugs are in the back right now so the 3-point works. If I put two quick connects on the 90 degree elbows, is the 3-point going to raise and lower each time I raise and lower the cylinder? Is there anything that can be done short of finding the right plugs for the remote cylinder? Thanks for any help. Bob
Mike M
08-17-2005 12:50:29
 Re: JD 60 Hyd Question in reply to Bobl1958, 08-17-2005 10:41:08
The one with the least resistance will lift first. Hook it up and find out. I had a loader hooked on my 50 the 3pt. would go up first then it would stay up and the loader worked normal only if you left the lever back for awhile did the 3pt drop.
Bobl1958
08-18-2005 06:49:37
 Re: JD 60 Hyd Question in reply to Mike M, 08-17-2005 12:50:29
Thanks for your reply. I'll plumb it in and see what happens.
