few questions 3020 load control shaft leak
Huckleberry
08-17-2005 08:36:28
I have read the archives on this but still have a few questions: for pulling a 10 ft mounted brush cutter, should the selector be in "D", "LD", or "L". I have mine in "D" for what the book indicated yields a 'floating action'. I am operating on hill ground. Will the new O-ring type seals totally eliminate the problem or should I consider going to a pull type brush cutter? The main issue here is that if you happen not to catch this early on the repairs could be more than the cost of a new pull type brush cutter.
twopop
08-17-2005 18:14:00
 Re: few questions 3020 load control shaft leak in reply to Huckleberry, 08-17-2005 08:36:28
www.bolingmachine.com
Glen in TX
08-17-2005 11:27:45
I'd replace with the bushings like Bob is talking about too and shaft while you're at it and shim it or your are wasting your time and money. I was able to get shim washers for last one I did on a 2510. Always ran it in LD also. You would need some stout skids or training wheels to be running it in D all the time. Too much action for a shredder and you'll tear something up.
Tx Jim
08-18-2005 04:18:00
 D vs LD vs L in reply to Glen in TX, 08-17-2005 11:27:45
JD's operator manual states that L is far load sensing for plowing,D is hight control for such things as blading or mowing where a set distance is needed,L&D is a setting in middle.On a properly set rockshaft on a JD in L or L/D one gives up some control of rockshaft so I mow in D.Also pulled implements exert some wear on load control seals because drawbar attaches to same piece as 3 pt hitch. Tx Jim
Mike M
08-17-2005 09:57:58
I'd replace the bushings (use aftermarket with the oring )also new seals and a shaft too.Make sure you shim up that yoke so you have no side play at all.I thought JD sells the shim kit ? As far as which position ? I run our 4020 in LD but a blade is about all I use.
Bob
08-17-2005 08:38:24
Replace the darn seals! It's certainly not THAT big of a deal compared to trading mowers!
