John Deere B Powertrol Lever Shaft Removal
8e3k0
08-17-2005 07:03:10
Need help and Advice: Want to remove the Control shaft and lever from the powertrol housing and would like to know if this can be done with housing in place and mounted to the tractor?
I notice from the Tech Manual that the shaft must be moved over and the woodruff key is driven out through a small hole in the shaft. Then the shaft is removed. If this is done is it possible to replace the woodruff key during shaft replacement with powertrol housing on tractor? Thanks for any help on this.
Ellis
F-I-T
08-17-2005 08:24:55
 Re: John Deere B Powertrol Lever Shaft Removal in reply to 8e3k0, 08-17-2005 07:03:10
Ellis:
I posted a reply to you on the other site, but anyway, on page 30-5-3 of the Hydraulics special manul SM-2011, it pretty much shows that you can remove the key from the top. You only have to have rear access if you need to remove the cam and deeper components.
Frank
Mike M
08-17-2005 07:11:51
I think I have done that in the past.Go ahead and give it a try. I'd place some rags in the housing to help stop that key from dropping down in and going bye bye.
