Mark, am I correct in assuming you have a GM 10 SI so called "3 wire alternator" and want to use it as a one wire configuration??? Cuz you can buy true One Wire alternators and all they require is they be grounded with their single big main output lug wired to the ammeters load side terminal. NOTE if youre gonna use like the GM 10 SI, you have to convert to Negative ground you know !!!!! !!!!! Do you have gas tractor????? ? If you e mail me at [email protected] I can return e mail you a wirign diagram for the GM 10 SI cuz a picture is worth a thousand words, but until then heres the basics for a gas tractor. From the Ignition switches IGN output (thats the circuit down to the coils high input (NOT to distributor) terminal, use 16 Gauge wire and install a 5 amp or more, 50 PIV diode (+ Anode to IGN - cathode towards alternator) plus a series 10 ohm 5 watt resistor and wire it to the lil 1R terminal on the alternators side. Thats the excitation circuit and I like the added 10 ohm resistoir to protect the small diode trio. Some people just tap off the ignition coils high input (NOT to distributor) terminal (that can work preferably when theres no external ballast resistor) and then add the diode n resistor, but I prefer to run its individual circuit down from the ignition switches IGN output terminal. NOTE (the possibly larger than necessary ratings are for heavier leads and easier wiring). On tracors using an idiot light charge indicator, its possible to use a wire from the idiot light and adding maybe a 5 ohm or so resistor (need 10 ohms total of light plus added resistor) and wiring it to the lil 1R Alternator terminal instead of from the previousoly described ignition circuit. From the Alternators other lil 2F side terminal, run a 16 gauge jumper wire up to the alternators big main rear output post. I use a 10 Gauge wire wired up from the Alternators big main rear output stud to the ammeters load side terminal. Thats the same place and circuit that used to be wired from the Voltage Regulators BAT terminal up to the ammeter, but I like to use bigger wire on the GM alternator. DONT FORGET TO CHANGE THE BATTERY TO NEGATIVE GROUND. With an ammeter you would have to swap its leads or ot will read backwards and I would swap the coils leads so - now goes to the distributor. Clear as mud??? John T in Indiana
