D Fuel Parts
Skyhawk Greg
08-16-2005 15:36:07
Hello,
Tried the usual suppliers and cannot find what is needed. Tried the not usual suppliers, and came up with the same thing.
Does anybody have, for sale, either of the two following parts:
1.) Page 38, Key 20, AC102R, Gasoline Strainer Elbow
2.) Page 38, Key 28B, AD1012R, Gasoline Line
The above references are from John Deere Parts Catalog PC658.
Thank you,
Greg
Glen in TX
08-16-2005 18:34:03
 Re: D Fuel Parts in reply to Skyhawk Greg, 08-16-2005 15:36:07
Greg, You may already know but the AC102R subs to a B2081R which they don't show available either. I think you can make the A2956R strainer for the styled D work but JD shows it at 24.68 ! I check and see if I have any or it can be sub. with something else or the later one. Might also get lucky and find that at old hardware or auto supply and not the new guys around the corner. As for the fuel line you can make it with 5/16" copper line and use your old glands and nuts and solder them on or buy new E2150R glands and A2069R nuts from JD still. You may also want to call Roberts Carb tomorrow about these parts if you didn't already as he shows to have the glands and nuts too.
Jim Benson
08-17-2005 08:10:22
 Re: D Fuel Parts in reply to Glen in TX, 08-16-2005 18:34:03
The A2956R JD now supplies has no screen, just a slotted riser. I took the old original off my A and heated to loosen solder, shortened up the bad area on the screen, and resoldered- lot cheaper and I hope better.
Glen in TX
08-17-2005 11:14:28
 Re: D Fuel Parts in reply to Jim Benson, 08-17-2005 08:10:22
Greg, Jim is right that the A2956R elbow is solid brass and sticks up being slotted on extension and open on top but it is 1/4" NPT also instead of 3/8"NPT as needed on yours. It would work if you didn't mind using a reducer at tank. What I would do if you have the old elbow is solder on a new screen or fit a piece of copper tubing inside the elbow letting it stick up a 1"-1 1/4" and then cut 2 slots down it 90 degrees from each other. Same fix many of us have used on the sediment bowls on tank. The elbow threads for the nut are special like 1/2"-24 straight so a 24 thread file would straighten threads on elbow to use with new nuts and glands and you'll have it looking original again.
