3 Position lite switch wiring problem-Need Help!
Randy G.
08-16-2005 11:06:25
My 1940 B has a 3 position lite switch that changes the charging rate of the generator (higher 6 volt charge,pos ground) at the 2 outer positions. The generator was rebuilt and charges fine but the lite switch it self get hotter than he!! None of my service manuals have a wiring diagram for this setup to help me diagnose the problem. Please help with advise, a diagram or both!! I'm afraid if left this way it may catch fire. Randy
buckeye al
08-16-2005 14:44:48
 Re: 3 Position lite switch wiring problem-Need Hel in reply to Randy G., 08-16-2005 11:06:25
The original gnerators for these were self excited three brush generators with a movable third brush. The third brush being the source of field excitation current for the generator's field windings.
For the missing info from the wiring schematic.... The field wire of the generator should connect to the non grounded end of the wire wound resistor on the light switch. With the switch pushed in all the way, the field current should go THROUGH this resistor to get to ground via the brass tab surrounding the mounting post. (Been a long time since I monkeyed with one but seems to me they're 'bout 2 Ohms.) When the switch is in either of the outer positions (high charge or high charge with lights on) the resistor is shorted out by the switch allowing more excitation current through the field to ground raising the generator's output. I have seen the lights connected to this resistor and that is NOT correct. The resistor is not for a bright or dim lights situation, it is only for the generator's field current!
Sooo.... Why is your switch getting hot? First off, make sure your switch is wired correctly then at fast idle with the switch all the way in, what is your charge rate? If you're charging 10 or 15 amps that's too high and you need to lower your charge rate. At fast idle it should charge only about 4 amps with the switch set to the low charge rate.
To adjust the charge rate, remove the dust band from the generator. On the commutator end frame of the generator there should be a slotted (usually slotted) screw that holds the third brush clamp in position. Loosen that screw and rotate the third brush around the commutator AWAY from the ARM or GEN brush to lower the charge rate, closer to the ARM or GEN brush to raise the charge rate. Again it's been a while since I was there but I seems to recall a 4 commutator bar spacing bewtween these two brushes was a good SWAG to use for starters.
For bench testing after the re-build the rebuilder probably left the third brush right up against the GEN brush and is thereby over exciting the field.
Post back with your findings or other questions.
Later.
John T
08-16-2005 14:26:13
Randy, the first thing I would check is that the switch has a good ground. It may have a resistive path (maybe carbon) to the sheet metal of the dash plate or the dash plate itslef isnt well grounded and heat is developing at the resistance. Another possibility is the switches internal contacts are resistive and/or carboned up and need a clean up and tightening but I doubt thats very possible or practical. Its regulating resistor may be bad also, its like a small wire wound unit and it could be heating up??? I think Jim at Agri Services has those new switches. There should only be like a couple ohms or less at low charge and the Generators Field needs to see a near zero resistance via the switch (including its internal resistance and contacts etc.) to ground for high charge. Use an ohm meter to test it and make sure of its to frame ground.
John T
