3020 hydraulics
ZA766
08-16-2005 10:25:26
I know I have seen mention of hydraulics quite often in this forum, but have never really needed any work on this until now. I have a early version JD3020(Ser.#69387) that has developed problems with the hydraulics. The first problem was that it acted as if the left rear wheel would lock up intermitently. I had a leak in the brake area and overhauled with new o-rings and cylinders at the brake pedals. This eliminated the leaks and I also changed the hydraulic filter. There was no metal or other stuff in the filter and it appeared very clean. I have bled the brakes according to the IT manual. Now I have problems with intermittent hydraulic brake functions and it has started to also effect the steering function. You can definitely hear when the main pump is on and off from the sound of the pump and engine and know when you have hydraulics and don't have. Is there something I have overlooked, or do I really need a main pump overhaul and just how hard is this for an amateur like me. I also remember hearing about a screen in the system that may need cleaning but the IT manual did not show this. Do you know if my tractor has a screen and where it is located that I should have checked. Any advice would be greatly appreciated as I want to avoid having to pay the dealer for service at his prices for as long as possible. Many thanks for everyone's help.
woodbutcher
08-16-2005 13:17:25
 Re: 3020 hydraulics in reply to ZA766, 08-16-2005 10:25:26
I recently had a problem removing the plug to check the screen on my 3010. It is on the left side behind the hydraulic filter. I think your 3020 will have it in the same location. My original plug had a square 1/2" casting to put a wrench on. I rounded the shoulders and had to drill it out. The replacement has a 1/2" square inset for a 1/2" square drive.
I hope you get more followups on this. I don't have brake problems, but when using my front-loader, the pump seams to quit similar to yours.
msb
08-16-2005 19:45:41
 Re: 3020 hydraulics in reply to woodbutcher, 08-16-2005 13:17:25
Do as Woodbutcher says and if you still have problems,get back with us.No need to do a lot of speculation as to what it could be and what it couldn't be until you pull than screen and check it out.Oh and by the way, you will have to drain the transmission.Better have 3-clean 5 gallon buckets at the ready when you pull the plug under the transmission.
