2640 jd
wkearns
08-16-2005 04:11:47
pto problems, is there any sure way to tell if the clutch pack is bad or if there is a problem in the hydrolic valve that switches it on
buickanddeere
08-16-2005 07:35:17
 Re: 2640 jd in reply to wkearns, 08-16-2005 04:11:47
Hydraulic Have you tested the clutch pack apply pressure? Are there any other hydraulc problems? The wrong oil will make clutchs slip. Even destroy the facing material when the machine is just sitting. Did you search through the parts and service manaul to find out more? Mother Deere has the parts manual online. Any material stuck in the hydraulic screen and filter? When was the filter and screen last serviced? Has the engine been turned up for more power? What pto load are you running?
wkearns
08-16-2005 18:35:30
 Re: 2640 jd in reply to buickanddeere, 08-16-2005 07:35:17
i was mowing one day and hit an ant bed and the pto quit i changed the hydrolic oil both filters also the shifter boots because it was getting water in the oil i can here a noise around the cover that i have not ever noticed sounds like something with low oil like a power steering pump the pto tries to turn but not under a load the lift is shaky and the steering also at times but most of the time the lift and steering works fine thanks far any info
buickanddeere
08-16-2005 22:42:25
 Re: 2640 jd in reply to wkearns, 08-16-2005 18:35:30
You are in for at the very least a pto clutch or replacement of a twisted driveline component. The hydraulic problems are scarey. What kind(s) of oil has been used in that tractor? When was the last oil filter change and screen cleaning? It maybe cheaper to trade even with the dealer knowing she has problems. The trans oil pump pressure has to be tested. Do the hydraulic problems get worse when the pto is engaged?
wkearns
08-17-2005 04:17:34
 Re: 2640 jd in reply to buickanddeere, 08-16-2005 22:42:25
i can change both filters and new oil and everything works ok but the pto it will try to turn when it is engagedbut you can stop it will just a little bit of pressure i have the service manualand have also talked to my local jd mechanic , not a lot of help i was just hoping there was an easy way to check the clutch pack i will get it under the old shade tree and start from step one thanks a lot
Tx Jim
08-17-2005 04:40:28
 Re: 2640 jd in reply to wkearns, 08-17-2005 04:17:34
If you have ind.pto under gear shift cover there are ports to check operating pressure for pto.clutch and brake. I think it should be 175 psi.Unusual noise could be cracked line that feeds pto clutch pack. JIm
buickanddeere
08-17-2005 16:01:26
 Re: 2640 jd in reply to Tx Jim, 08-17-2005 04:40:28
Tx Jim's idea of a cracked line or failing valve makes sense. The trans charge pump maynot be keeping the front high pressure pump fully primed. Before reducing the tractor to a pile of parts and trying to find the failed part in the heap. Get a pressure gauge set and find out what pressures and where.
