JD 400 Starting Problem
Ryan1966
08-15-2005 23:57:27
Hello, I have a JD 400 industrial, has a gas 4 cylinder. I am having some problems getting it started when I have the hydraulic pump hooked up. When the pump is hooked up it will turn over, but it sounds like its straining, and I can hear it trying to pump fluid to the back hoe. But when its off, the tractor fires right up. It is a little low on fluid, but I don"t think much. Could it be a bad hydraulic pump? Another problem is when it was last started, the power steering was leaking, I don"t think that it should have high pressure in the power steering like it seems to have. Any information would be appreciated. Thanks
Ryan
Roy Suomi
08-17-2005 19:48:14
 Re: JD 400 Starting Problem in reply to Ryan1966, 08-15-2005 23:57:27
On these older tractors you can unload the hydraulics by turning the steering wheel as you attempt to start it.Just turning the wheel back and forth a little will do it. There is supposed to be a valve in the front cover of hydraulic pump that unloads the pump just barely enough to start.When you're cranking the engine ,you are building 2300 psi of oil pressure. I've replaced the front cover with a 310 or 410 front cover with a destroking solenoid. This unloads the pump at start everytime...
