4020 Stolper cab ?
Nylon
08-15-2005 23:06:22
Hi,
I am getting closer to talking myself into this brake job. I have seen cabs in parts but looking at this stolper it appears that pieces may be tough. Is it possible to remove the bolts from all the lower cab area and the roll bar at axle? And remove rollbar / cab as a unit with a hoist? Or is this just a bad idea? It seems possible to me with a stressed member used above the roll bar and some heavier angle bar to stabalize and bolt to roof at key points.
Thanks,
JOhn
JDBert
08-16-2005 06:38:24
 Re: 4020 Stolper cab ? in reply to Nylon, 08-15-2005 23:06:22
Thats probably the best way to do it. There are 2 front mounts and then the rollbar mounts, I think you have to remove the seat assembly and all the tin around the hood area, electrics and heater hoses, A/C if you have it as well. I moved out my rear wheels, hung the cab from my shop rafters (I have heavy clear span rafters that can take the load) and then just rolled the tractor out from underneith it, set the cab down on a trailer and moved it outa the way
