JD 112 question
Brian Burns
08-15-2005 21:11:11
I recently bought a JD 112. 1968 I think. Seller stated it has a 42" mowing deck. What tools are required and how difficult is it to remove the mowing deck for transport? Any advice on this model would also be welcome. I am new to JD and interested in "tinkering." Thanks,
Brian
Maark
08-16-2005 11:08:32
 Re: JD 112 question in reply to Brian Burns, 08-15-2005 21:11:11
All that is required is a set of pliers. remove the drive belt by loosening the tightener sticking out of the front of tractor[black knob], or just roll the belt off the pulley on the deck. Then remove 2 spring pins on the lift arms, continue by pulling 2 spring pins on the arms that carry the deck. Finally pull the 2 spring loaded pins out of the front of the deck by the antiscalp wheel. Deck will then slide out from under the tractor. You may need to turn the wheels one direction to be able to pull the deck clear of the tractor. I think if you go to get new blades for that mower it will be a 41" deck, not 42"
