70 fanshaft hooooooooooooooooooooowls
bryan s
08-15-2005 18:41:35
i have a 70 that the last owner globed so much silicone over everything when he put it back together he plugged the oil return hole behind the vent pump/fan shaft housing which caused oil to leak out behind the fan pulley.well i took the fan shaft off(no power steering) and also had to replace the rear ball bearing on the fan shaft.i used a gasket the same thickness when reassembling.well i guess the heel and backlash settings are now out the window on the drive gears cause this thing makes some much racket you can hear it a mile away-is there any short cuts on stting this properly without removing the governor?thanks
Kurt_JDB
08-16-2005 14:57:30
 Re: 70 fanshaft hooooooooooooooooooooowls in reply to bryan s, 08-15-2005 18:41:35
I just recently completely rebuilt the governor and fanshaft on a '51 B. I'm going to assume the procedure on the 70 is similar. Your milage may vary.
Is the bearing you replaced the one at the bevel gear end of the shaft? If it is, did you follow the procedure for pressing the bevel gear back on?
This procedure (for a 'B') involves pressing the bevel gear onto the shaft, installing the snap ring at the end of the shaft, and then supporting the assembly by the eccentric and pressing down on the shaft until the bevel gear moves back toward the end of the shaft to contact the snap ring. If the bevel gear is not contacting the snap ring, I do not think you will be able to properly adjust the gears.
At any rate, I do not think there is any shortcut to removing the governor if you want it right. It took me a couple of hours to set up the backlash and heel of these gears, with most of the time spent cutting different thickness gaskets to get it right. Good luck to you.
Kurt
Mike M
08-16-2005 05:46:09
How much play do you have out at the fan blades ? Do you have any ? Too loose is going to be better than too tight.
BushogPapa
08-15-2005 19:50:14
If it is Manual steering, has the front fanshaft bearing been greased lately..??? Could be it howling....
Ron.
