GPWT
BODY MAN JACK
08-15-2005 12:59:12
I HAVE A GPWT SERIAL NUMBER 400942 WHICH IS CALLED A 1930 . WHERE CAN I FIND MORE IMFORMATION ABOUT HOW MANY HAD THE SOLID CAST FT WHEELS . I DONT SEE MUCH ABOUT GPWT WITH SOLID CAST TRICYCLE FT ENDS,
Duane Larson
08-15-2005 19:17:26
 Re: GPWT in reply to BODY MAN JACK, 08-15-2005 12:59:12
BodymanJack,
The cast front wheels were actually rather common on GPWT tractors. Part number AC847 (casting number C334R), they were standard issue on GPWT from 400000-402668, and available later. They were often referred to as "Texas wheels" or "sand wheels". They used hub AC513 (casting number C391R).
My wheel notes are in the shop, so this is from memory. If I am wrong, I will repost tomorrow with corrected info.
JDGPWT31
08-15-2005 15:58:18
Hi,
BODY MAN JACK,
I HAVE A 31 GPWT FOR MYSELF AND NEVER HEARD OF ANY EVER HAVING CAST FRONT OR EVEN REAR WHEELS. YOURS MIGHT BE OF SOME MODIFCATION THAT SOME ELSE HAS DONE BEFORE. CHECK THE TWO CYLINDER CLUB FOR MORE INFO. HOPE MY INFO HELPS YOU OUT.
JDGPWT31
