How to remove sliding gear shaft on 1939 B?
JDVan
08-15-2005 10:09:14
I"m having trouble figuring out how to remove the lower sliding gear transmission shaft from a 1939 JD B main case. I have the upper shaft and gears out but can"t seem to get the lower shaft and gears out. Have the end caps off and left bearing race out but am stuck. Help????
Mike M
08-16-2005 14:56:32
 Re: How to remove sliding gear shaft on 1939 B? in reply to JDVan, 08-15-2005 10:09:14
I looked in my parts books and that early tractor has no snap ring so ignore that. If you can somehow get the left hand bearing off and if the hole on the right hand side in the case is big enough to pass the bearing and washer behind it the shaft may slide out to the right,leaving the gears behind. It either will go out the right or else the diff. has to come out and try to get it up and out. If you are planing on pulling the diff. anyhow do it first and try that way.
JDVan
08-16-2005 12:55:01
I may have mislead by using the wrong name of the shaft I'm trying to remove. I have the sliding gear shaft out but not the shaft below it, the counter shaft with associated gears is what I cannot get out.
Jason Z in MO
08-16-2005 12:40:58
I am pretty sure you have to remove the differential. I did with my very early styled.
Mike M
08-15-2005 10:19:36
I seem to recall that I had problems like that with an unstyled B. You may need to remove the RH bearing also. I can't remember for sure,but most all other newer B's also have a snap ring on that lower shaft next to the idler gear assy. You may have a notched spacer you have to reach into with snap ring pliers "flat nosed" and loosen as you pull it out ?
JDVan
08-15-2005 16:58:05
 Re: How to remove sliding gear shaft on 1939 B? in reply to Mike M, 08-15-2005 10:19:36
Thanks for the response but I haven't gleaned a solution from it. I tried to slide the assembly to the left but cannot get the right end up. Tried sliding to the right and then can get the left end up but front of transmission case and differential gear interferes. There must be some trick. Help?????
Mike M
08-16-2005 06:20:22
 Re: How to remove sliding gear shaft on 1939 B? in reply to JDVan, 08-15-2005 16:58:05
I don't think the service manuals cover that year either. If you get that RH bearing off do you think the LH bearing and shaft will come through the case ? You may end up having to pull the diff. ?
JDVan
08-25-2005 10:45:40
 Re: How to remove sliding gear shaft on 1939 B? in reply to Mike M, 08-16-2005 06:20:22
Since I am parting out the tractor, I just pulled the rear axle housing and differential. The bottom transmission shaft came out easily then. Thanks.
