JD 720 LP ran, not now
Ben Ridgeman
08-15-2005 09:46:37
Hi, I bought a non-running 720 LP, had the converter rebuilt, was able to run get the tractor to run, but the exhaust sent up flames and the manifold was hot....now, I cant get it to run at all. I have spark and it turns over, but wont run.
I hear that it may be running lean and timing may be off?
Where do I set the carb and how should the timing be set to at least get the engine to fire?
Also, the fuel in the LP tank leaked out...is there a minimum amount of LP I need to add...can I just add a gallon, or will it take more than a small amount to open the regulator/convertor.
Thanks for all your help in advance
BushogPapa
08-15-2005 19:59:55
 Re: JD 720 LP ran, not now in reply to Ben Ridgeman, 08-15-2005 09:46:37
I sure could use your pointers, too..!!
JD 630 LP here...
Thanks..!!
Ron..
CLW
08-15-2005 20:57:49
 Re: JD 720 LP ran, not now in reply to BushogPapa, 08-15-2005 19:59:55
Ron, I can't, for some reason send you an e-mail. Would you try to send me your address.
[email protected]
CLW
CLW
08-15-2005 13:31:16
Ben, if you will send me you email address I will try and send you some trouble shooting tips. It may take a day or two to get it back to you. You can get a hose made up by your LP dealer, or a auto supply store that will let you plug a small BBQ type tank into the fuel system to run the tractor while you are working on it. If you go to an auto store for the hose be sure it is a high pressure. (250 PSI or above) I have a 200 PSI that has worked, but my LP dealer said it should be 250. LP dealer would be the best place to get one.
CLW
Floyd
08-25-2005 21:14:33
 Re: JD 720 LP ran, not now in reply to CLW, 08-15-2005 13:31:16
Here, here! I thought I was the only one that had a 720LP that only ran long enough to get it on the trailer!
I would appreciate ANY and ALL suggestions. I have swapped carbs with a running tractor and that didn't help. The carb off the 720 worked on the other tractor just fine.
What next? Thanks in advance.
