730 d powersteering
jdjack
08-15-2005 05:58:59
Just got done replaceing seals in pto shaft oil pump for leaking trans fluid into pto housing. Drove tractor home and noticed oil on front tires. Removed cover in hood to access power steering fluid. Oil is coming out of vent. Removed plug and got shot with some oil that is pressurized.
Level is way overfull. I beleive that engine oil is leaking in. Anybody seen this before, and what seals need to be replaced? Hope that is easier than the pto job.
Thanks JDJACK
GPULLER
08-16-2005 08:21:26
 Re: 730 d powersteering in reply to jdjack, 08-15-2005 05:58:59
My 720D was doing the same thing last year. The oil level was so high it was pushing out the vent/filler. At first I thought the vent was plugged, I cleaned the vent by soaking it in paint thinner over night. Sounds as though yours might be plugged also, there should be not pressure there. Still, it was gaining oil. I pulled the power steering pump off and replaced the seals because it was sucking engine oil from the govenor through the fan shaft. It really wasn't that bad of a job but you will need a press to get the fan off of the pump shaft. I replaced the bearing, and 3 seals, which are all availabe from Deere. The gears were in good shape, I used sealant that they use on motorcycle engine cases when putting the pump body back together. Works like a champ now and no more oily mess!
Mike M
08-15-2005 07:36:42
Welcome to the fun of 2 cyl. diesels !! They are masters of mixing fluids and self destruction.
